Old 04-10-2016, 11:44 AM   #1
Fuse for dash 12v plug location
Newbie here. I think I blew the fuse to the 12v dash plug. The plugged an air compressor in and it shut down. Now navigation and other accessories don't power up. Where can I check to see if fuse is blown?
Melvinson404 is offline   Reply With Quote
Old 04-10-2016, 11:51 AM   #2
Kenny kustom's Avatar
Usually it's tied to the radio fuse
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 04-10-2016, 11:52 AM   #3
On my 2015 335, its right under the dash where the plug is. In line fuse holder I believe 7 amp. Easy to find
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 04-10-2016, 11:59 AM   #4
Score!!!!!!!!!! You rock Scott!, thanks....
Old 04-10-2016, 12:04 PM   #5
Now cut that plug off the compressor, and put a pair of alligator clips.
2016 Sabre 36QBOK
Old 04-11-2016, 06:58 PM   #6
Saltyrod
Send a message via Yahoo to saltyrod
I had/ have an in-line fuse on my FR3, under the dash, (this is in addition to the normal fuse panel). If you follow the wire from the cig plug you should find it fairly easy). Good luck!
saltyrod is offline   Reply With Quote
cat, fuse, location
