Newbie here. I think I blew the fuse to the 12v dash plug. The plugged an air compressor in and it shut down. Now navigation and other accessories don't power up. Where can I check to see if fuse is blown?
I had/ have an in-line fuse on my FR3, under the dash, (this is in addition to the normal fuse panel). If you follow the wire from the cig plug you should find it fairly easy). Good luck!
