Old 11-19-2014, 12:06 AM   #1
Fuse for water pump
We have 378TS 2008 GT. Winter full timing right now. The inline fuse for water pump blew once, replaced it and all was fine for a few days. The pump is not working again but the fuse is good. Wondering if there is another fuse somewhere? It has been cold but we are keeping everything warm underneath. So also wondering if the pumps don't work when it gets to around 10 degrees? Nothing is froze, but water pump is close to outside, it's about 40 degrees in that compartment.
Gary
Ggantilla is offline   Reply With Quote
Old 11-19-2014, 06:29 AM   #2
TURBS's Avatar
Gary check voltage at the fuse you recently replaced to see if you have power there or not.
TURBS.
Old 11-19-2014, 07:49 AM   #3
Ok will do. I had leave for couple days, so will check when I get back.
Old 11-19-2014, 08:39 AM   #4
TURBS's Avatar
Btw consider buy a volt / ohm meter just for your camper.
You'll need it again!
TURBS.
fuse, pump, water, water pump
