Old 05-12-2011, 08:38 AM   #1
fuse locations
2010 georgetown 300s does anyone know the locations of the various fuses other than the panel on the bed frame
rogann is offline   Reply With Quote
Old 05-12-2011, 08:53 AM   #2
On my 2009 374 Georgetown the majority of the fuses are located above the house batteries. You need to take off the cover on the steps. Be careful when you take off the fuse cover since it is metal and if you drop it it can short out the batteries. GREAT DESIGN !
peskin is offline   Reply With Quote
Old 05-16-2011, 06:19 AM   #3
CLASS "A" Senior Member
cfsoistman's Avatar
All of the fuses associated with the chassis are under the hood next to the air cleaner and under the driver's side dash near the floor & sterring column. The fuses related to the coach are both under the steps as peskin stated and in the elctrical panel as well. There are a some in-line fuses as well for the steps and a few other items. I'd recommend tagging them when you figure out what goes where. Hopefully you'll never need to track down fuse issues but in case you do it's easier when they'll labeled.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 05-16-2011, 07:21 AM   #4
Do yourself a favor and next time your at Home Depot or a auto parts store pick up a fuse kit. Great and inexpensive insurance. I learned that the hard way when on my first trip the electric steps bound up against a cement patio blew fuses. Lucky for me the dealer was able to walk me thru where they were located and I was able to borrow a spare from another camper.
