Old 09-25-2016, 04:25 PM   #1
Sbryant's Avatar
Fuse Propane Water Heater
FR '14 GT 360 XL. Anybody know where the fuse is for the Water Heater heating on Gas? It works on electricity, but won't fire up on gas. Thanks
Sbryant is offline   Reply With Quote
Old 09-27-2016, 12:55 AM   #2
ramair's Avatar
If you have a Suburban water heater the reset buttons are covered by the rubber cover just under the pressure relief valve. The right is the gas and the left is the electric reset buttons. Also if the water inside the water heater is not below the preset limits the gas side will not come on. If you turn the switch on for the gas inside the MH and the red light does not come on then the water is too hot for it to ignite. If you run the hot water for a few minutes then try to turn it on. Sorry I don't have the diagram for the WH.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 09-27-2016, 04:08 PM   #3
Sbryant's Avatar
Thanks - that fixed it !!
Old 09-28-2016, 01:42 AM   #4
ramair's Avatar
Glad I could help.
2015 Ford Taurus
Our Baby Dachshund
Cammie
fuse, heater, propane, water, water heater
