Old 04-22-2013, 07:17 AM   #1
jvish33's Avatar
Gen set issue on the 351dsf
Picked up the new 351dsf on sat. Over all everything is good except when I got it home I started the Gen Set and it ran for about 5 min then shut off. Cant get it to start again. ?? Dosent seem like its getting fuel. I have plenty of gas in the tank (Half tank). Followed all the starting instructions. Same as the one I had in the C except its a 5500. Any suggestions?
Other then that all is well. Tested all the other systems with no issue.
And yes you guys were right. Very easy to drive!
jvish33 is offline   Reply With Quote
Old 04-22-2013, 08:01 AM   #2
Iggy's Avatar
Congrats on the new Geeorgetown. Spend as much time as you can learning and finding all you can about your new MH. PLug it in to and see how things work before you leave home for your first trip.
Now for your question I must ask you a few questions.
Is the house batteries fully charged?
Are you plugged into shore power to charge the batteries?
Is your master battery switch on?
Good Luck
If it cranks but won't start maybe the dealer needs to check it out.
Old 04-22-2013, 09:47 AM   #3
jvish33's Avatar
Good Luck
Thanks Iggy
yes bats are charged. I am not pluged in wile trying to start....
does crank but no go. Ran for about 5 min then shut down..
I am going to call the dealer today.
Old 04-22-2013, 11:52 AM   #4
kenandterry's Avatar
Just throwing this out for consideration........
You mention you have plenty of gas (1/2 tank). Is the motorhome level? If not, it's possible the fuel drawing tube for the generator is not actually immersed in the gas available. Also, not all fuel gauges are created equal. Is there really that much gas in the tank? It's a brand new rig. Do you really know, or just going by the needle on the dash?
Just saying.............
Could just fill it up and be sure, then retry the generator.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 04-22-2013, 12:04 PM   #5
lochsa's Avatar
Yep, my generator exhibits the exact same behavior on my 330ts when I'm below or at 1/4 tank mark. I'd add a few more gallons of fuel for the heck of it.
lochsa is offline   Reply With Quote
Old 04-22-2013, 12:34 PM   #6
Iggy's Avatar
YES never let your gas tank get below 1/4 of a tank as the generator pickup tube is at that level. It may suck air until you add some fuel.
This is designed that way just in case you need to drive some where in an emergency. It stops you from running the tank dry by using the generator.
Old 04-22-2013, 01:14 PM   #7
jvish33's Avatar
Ok Just to be clear.. I have a little over a Half a tank of gas. I am aware of the shut off point. Thats not it.
Rig is level
I checked the 7.5 fuse that is in line with the gen fuel pump and also cleaned the contacts on the connector wires coming from the pump.. Still no go. I should be able to hear the "clicking" noise from the pump wile it is priming. I am not.
Soo... I have a bad fuel pump from the factory. I guess dealer didnt run it wile doing his checks...
Not sure what else it could be.
Old 04-22-2013, 01:35 PM   #8
Eric52's Avatar
When I received my 350 ts I used the generator also and had the same problem. It shut down because the oil level was low. There was less than a 1/2 liter. There is a low oil shut off. You may need to just add some oil. You should also check that your slide out reservoir is full also.
Eric52 is offline   Reply With Quote
Old 04-22-2013, 01:45 PM   #9
jvish33's Avatar
I checked that as well... looks good. In the safe zone or full area but not way up the stick if you know what I mean. also after I over crank it... It gives me a error code 2 (low oil)... but figured it was ok beacuse of the level on the stick... but I am going to try and add a little more Oil.
thanks!!!!
Old 04-22-2013, 03:09 PM   #10
jvish33's Avatar
Not oil.. added some and no go. Dealer agrees that it is the fuel pump to the gen set... bad.
Oh well things happen.. will get it fixed
thanks all for your help!!!
