Carb may need a more thorough cleaning. Get into the jets, float, even the intake manifold may need cleaned. If you get it back running, try to use ethanol free gas in it. If that's not an option, at least make sure the fuel is treated with stabil or something similar. If the gen has it's own battery for starting, make sure it's still good. A bad battery can rob power from a small motor's spark causing it not to fire properly as well.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
