Old 06-27-2013, 12:47 PM   #1
kenandterry's Avatar
GENERAC 6500 won't start
Over the winter I exercised our Generac 6500 gas generator religiously every two weeks through the winter. I would run it at least 90 minutes each time, and had it power a couple of electric baseboard heaters, a few appliances and some lighting...........just to put a load on it. It performed flawlessly.
I will add here, the gas tank for the motorhome was full, full, full, and by springtime, still showed full.
One time during the winter, it started as normal, and within a minute of running, it went to a very high engine speed.......higher than I had ever heard. Within 30 seconds, it did NOT correct itself, and I manually shut down the genny. Now it won't run, but it will attempt to start itself as it turns over a couple of times, then flashes the lamp on the start rocker switch 7 times, which is the fault code for "UNDERSPEED" according to the manual.
Any hints?
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 06-27-2013, 03:04 PM   #2
miked11272's Avatar
I had the same problem it was a bad printed control board. It is about 200.00 and 20 minutes to install. Download a trouble shooting manual and check the 14 wire to the thermal block it was not crimped property I believe it caused the control board to short out. If you need the manual I will try to send it to you.
miked11272 is offline   Reply With Quote
Old 07-05-2013, 10:34 AM   #3
The Generac documentation I have really doesn't go in too deep about troubleshooting. Like I mentioned, the flashing light on the start switch flashes 7 times indication "Underspeed".....what ever that means.
Look forward to any documentation you can send my way.
Ken
Ken and Terry
Old 07-06-2013, 01:53 PM   #4
miked11272's Avatar
Exact same thing my generator did flashed 7 times under speed when it actually had to high of rpms . The board is giving a false reading causing the governor to pull down on the throttle. If you go to smokestack.com my post is on there or try to Google generic RV 6500 running at high speed. Good luck let me know how you make out
Old 07-06-2013, 04:51 PM   #5
miked11272's Avatar
http://www.smokstak.com/forum/showthread.php?t=111674
This is the link for smokestak.com.
Old 07-06-2013, 05:09 PM   #6
VinceU's Avatar
Ken
Underspeed means the. Speed sensor is not feeding the governor control. Could be the control board or speed sensor itself is bad. When either failed, the governor applied full throttle to catch up, obviously it couldn't. The sensor is simply a magnetic pickup.
Old 07-06-2013, 05:40 PM   #7
miked11272's Avatar
Here is the link. http://gen-parts.com/Manuals/0G7675.pdf
