Originally Posted by sparks1032
Yes on level ground and I ran it for several minutes still high and not sure how much drained as I opened the tube and let it drain until no oil came out. Next time measuring would be IDEAL but never had this problem with small engine oil change.
Did you open the fill tube while draining?
It need an outside air balance to drain fully.
Does the present oil fill oil look clean and clear or dirty?
