Old 10-29-2014, 08:45 PM   #1
ME
sparks1032's Avatar
Generac oil change
Took the time to find the manual and it said to change oil and filter 1.9 quarts and after draining it (It took 30 minutes) was way over the maximum fill. Has anyone else had this problem? Here is a few pictures
ID:	65567   Click image for larger version
2008 Georgetown 350TS
sparks1032 is offline   Reply With Quote
Old 10-29-2014, 10:01 PM   #2
Iggy's Avatar
Dumb question but were you on level ground?
Have you started to engine to circulate thru the oil filter?
If you are and it is over filled you never drained all the oil out.
Did you drain approx. 1.9 qts out?
Let us know what you figure out.
Iggy is online now   Reply With Quote
Old 10-29-2014, 10:46 PM   #3
Just to cover all bases.. You did start it and let I run for a few ..before you checked it??.. Oil has to circulate to fill filter..
2010 Georgetown 300FWSSouth Florida
speedjester is offline   Reply With Quote
Old 10-30-2014, 07:57 AM   #4
ME
sparks1032's Avatar
Yes on level ground and I ran it for several minutes still high and not sure how much drained as I opened the tube and let it drain until no oil came out. Next time measuring would be IDEAL but never had this problem with small engine oil change.
Old 10-30-2014, 09:45 AM   #5
Iggy's Avatar
Did you open the fill tube while draining?
It need an outside air balance to drain fully.
Does the present oil fill oil look clean and clear or dirty?
Old 10-30-2014, 10:06 AM   #6
Never heard or seen a crankcase that required the filler cap be removed to allow oil to drain. IC engine crankcases have to be open to the atmosphere to operate.
Old 10-30-2014, 10:15 AM   #7
Iggy's Avatar
OldCoot just trying figure out why he is over filled.
Maybe the oil breather is clogged. If that happens you will cause a vacuum in the oil pan area which will restrict the oil to come out below.
Old 10-30-2014, 10:23 AM   #8
IMO, that's a real stretch, especially on a relatively new unit in a protected compartment.
Old 10-30-2014, 10:31 AM   #9
Iggy's Avatar
New unit? It is in a 2008 Georgetown.
And it is not in a protected compartment. It is open to all the road junk.
Old 10-30-2014, 11:15 AM   #10
The pictures show a pristine unit in a compartment.
