Originally Posted by KansasFR3
The black plastic shroud is supposed to be trimmed based on your specific clearances. I had to trim off about 2-3" from what was sent to me so it left me with a 1/2" clearance to the gen door. As long as you have the real estate on the exterior door for the trim piece, you good.
I believe the air intake on the Georgetowns is on the bottom of the unit, whereas on FR3s it is through the side. So adding a vent to the basement door will not help in this situation.
