Old 04-28-2016, 01:12 PM   #1
Generator Exhaust Extensions
Has anyone made an extension for their generator to get the exhaust out from under the slide?
Truckdogg4 is offline   Reply With Quote
Old 04-28-2016, 01:35 PM   #2
RVnut's Avatar
Now that I think about it that is a dumb place for it to be on our 364.. I have not noticed any fumes yet.. Our old Thor had the pipe go up to the driver side front tire
364 Georgetown 2016
in Montana
RVnut is offline   Reply With Quote
Old 04-28-2016, 01:57 PM   #3
Never been a problem on my 335DS. You are right it is under the slide but generally when I run the generator I run the AC, so I have not seen a problem.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 04-28-2016, 07:19 PM   #4
fonzie's Avatar
many threads on subject......
https://www.google.ca/search?q=gentu...4GhtuOBPf2iIAL
Fonzie
Old 04-28-2016, 07:31 PM   #5
Left Coast
'Good neighbor pipe'.........
Old 04-29-2016, 12:37 PM   #6
When we our Gen overhauled, the tech took it upon himself to reroute the exhaust to the back of the coach. He said he liked us and didn't want us to croak due to the exhaust. Nice guy. Didn't charge me.
2014 378 xl
2005 Jeep Wrangler TJ
jeffv003 is offline   Reply With Quote
Old 04-29-2016, 12:45 PM   #7
2014 378 xl
The exhaust pipe will pivot to whatever direction you want. However, I don't think that just putting a long tube on it is a good answer. The exhaust extensions don't actually do that, they position the exhaust in the center of a larger diameter riser but leave room for air to enter and rise. A long tube will put too much resistance on the exhaust manifold and could affect the performance of the genny.
2015 335DS
Old 04-29-2016, 03:33 PM   #8
Left Coast
There are many racer type trailers that use an extension on the exhaust pipe to redirect the fumes up above where the crew next door is pitted and work'n......
Old 04-30-2016, 12:05 PM   #9
I believe I read in my 2016 Cummins - Onan manual that any extension invalidates the warranty and are not recommend. Not sure so please check.
2016 Georgetown 364 TSF
2015 FunFinder 242BDS traded for above
2014 Starcraft 1221 Comet traded for above
Modmike is offline   Reply With Quote
Old 05-02-2016, 02:05 PM   #10
gmann55's Avatar
I used a piece of 3 in aluminum irrigation pipe and took it to an exhaust place so they could bend it for me!
gmann55 is offline   Reply With Quote
generator
