I have a 2013 351ds but I think the generator location is similar. I took mine to a local muffler shop I found with a local Google search and online reviews. I extended the slide and they measured and cut a piece of exhaust pipe, opened the end, and bent it to the angle to connect with the genset exhaust. It passes under the slide and I attach the Genturi to the side of the coach with two suction cup type j hooks. If the extension pipe is cut to the correct length, the bottom of the Genturi will rest on the extension pipe, which will rest against the genset exhaust. It will all be supported by the bungee cords connected to the two suction cups. I think the shop took about 30 minutes and charged less than $20. Call the shop in advance and explain what you're looking for before you go and if they can do it, ask if there is a lighter time of day to stop by so there will be fewer objects to dodge in their parking area. For instance, my shop had me meet 15 minutes before their usual opening so I could get my rig in before their muffler appointments started showing up. You might also want to visit without your rig first just to make sure you'll be able to maneuver around the shop.
