Old 02-18-2015, 09:39 AM   #41
WDK
WDK's Avatar
ChrisandGarren mentioned the suction cups though early in this discussion when I had no clue of how to implement them around the slide and as like most ideas the piping came to me in the middle of the night. I did not think the suction cups would hold but the 4 inch cups rated at 65lbs a piece are over kill for my 12 lbs of piping total....again thank you guys for the feed back. I am not a salesman and can't bring myself to push something so simple. I am just glad I came up with something cheap that I can use in these rally situations.
WDK
WDK is offline   Reply With Quote
Old 02-18-2015, 10:15 AM   #42
I cannot take credit for the suction cups (other than mentioning them!) because I saw them on another website when I was doing research.
Glad it works on your test so far - if you happen to have the measurements you used to build it would love to use it (since we have the same coach!) in case we ever need something like that.
Garren
2015 Georgetown 351DS
2016 Jeep Wrangler Unlimited Sahara
Chris, Garren (humans)
Edgar & Carlos (felines)
RIP Sophie, the sweetest cat ever.
ChrisAndGarren is online now   Reply With Quote
Old 02-18-2015, 11:38 AM   #43
WDK
WDK's Avatar
....thank you.....I will send the exact measurements later when I get home....I was just cutting to fit. Any velcro straps long enough to go around 3" ABS work great. Looking at how I did it....if FR could put just some little keepers on the sides and bottoms to go between the rollers on the bottom and not disturb the rubber gasket on the side so you could get an strap through would be perfect but then that would mean they would have been thinking that you might need to vent up at rally's like this.
WDK
Old 02-18-2015, 11:52 AM   #44
Mojojojo's Avatar
From reading here FR gets plenty of venting around here , nice job on the riser. I think gopro mounts would work if the gel is clean for a more permanent mount.
My wife keeps saying I don't listen to her -Or something like that?...."My advice has no basis ,more reliable them my own meandering experience" Baz Luhrmann
2011 Sierra 355QBQ 1986 F350
Mojojojo is offline   Reply With Quote
Old 02-18-2015, 12:10 PM   #45
WDK
WDK's Avatar
.....anything that won't impede the slide operation or the gasket because at this juncture in my warranty, I don't want to give them a reason not to pay.....with the cups, you clean up the circles and nothing was ever there.
WDK
Old 02-18-2015, 12:35 PM   #46
WDK, appreciate it! Will make it easier to build our own someday.
you can either post or PM me is fine too.
Garren
Old 02-18-2015, 01:43 PM   #47
Freds342's Avatar
I use two 2" Suction cups, and they work fine for the thinwall PVC, about 5# max.
Also, the 1-1/4" exhaust extension should be below the pipe by about the distance off the pipe diameter, or, in my case 3". I have run my gennie 24 hours a day for up to five days.
The only problem I've ever had is the suction cups sun rotting.
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
Freds342 is offline   Reply With Quote
Old 02-28-2015, 09:29 AM   #48
WDK
WDK's Avatar
I have been at the rally in Phoenix 3 days now....I run my generator a total of 6 hours or so a day and I passed muster.....a lot of guys who spent upwards of $100 bucks at the rally to buy one are having different thoughts 😊.Click image for larger version
Name:	ImageUploadedByForest River Forums1425137389.501231.jpg
Old 02-28-2015, 09:46 AM   #49
fonzie's Avatar
Nice set up.....you might get water accumulation at the elbow at bottom of your stack if it doesn't drain....let us know if it does (for information only)
Fonzie
Old 02-28-2015, 09:56 AM   #50
Witch Doctor's Avatar
Originally Posted by WDK View Post
I have been at the rally in Phoenix 3 days now....I run my generator a total of 6 hours or so a day and I passed muster.....a lot of guys who spent upwards of $100 bucks at the rally to buy one are having different thoughts ��.Attachment 70420
Glad your design passed muster. Where they as bad as you thought about enforcing that requirement?......
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
generator
