Old 10-01-2014, 07:15 PM   #1
Generator Hour Meter
I just noticed something very perplexing !! We have had our 377 for 5 weeks. The hour meter had 5.7 on it when we picked it up and I have run the genset maybe 1.5 hours total. It now reads 75.9 and is slowly going to turn 76.0 ??? I am plugged into a 20amp circuit at home to clean and wash it before it goes to our covered storage! Any ideas???
Denny
DennyH is offline   Reply With Quote
Old 10-01-2014, 07:28 PM   #2
B47
Denny
Most HM I'm familiar with such as those on rental aircraft for the purpose of charging usage time are activated by oil pressure when the engine is started.
I'm a little curious that the number 5 is in both (5.7) and (75.9) readings. Perhaps the counter is stuck.
Just grab a brewski and sit and watch it for awhile and see what it does.
If you do have to replace it,remember to note the time displayed on it for future readings.
Old 10-01-2014, 09:34 PM   #3
Iggy's Avatar
Denny
Mine did the same thing.
It went from 30 hours to 76 hours and I only ran it for about 4-6 hours between those numbers.
If you want to replace it and start at zero again here is a good source.
Allied Electronics
Old 10-01-2014, 09:38 PM   #4
Allied Electronics
I'm assuming I need the 12v model??
Old 10-01-2014, 10:04 PM   #5
Iggy's Avatar
The model I linked works on 10 volts DC to 30 volts DC.
It will work on 12 VDC.
Does yours look like the one I linked?
It is what I have in my 2012 378TS XL Georgetown
Old 10-01-2014, 10:11 PM   #6
B47
Ok - I have an question.
Everything I'm reading here indicates that this HM is recording the time the MH is plugged into electrical power even if it's not recording.
If correct,then what use is it? All HM's I'm familiar with record the running time of the unit it's installed on.
Old 10-01-2014, 10:13 PM   #7
B47
Sorry meant to say "when it's not running."
Old 10-01-2014, 10:15 PM   #8
Hmmmmm
Old 10-01-2014, 10:38 PM   #9
Iggy's Avatar
No this measures the run time of the generator and has no interconnect to shore power.
Old 10-01-2014, 10:48 PM   #10
B47
Ok - now more confused. The OP indicates in his post that the gen has run a short time and the HM is still recording hours.
So if the HM is not interconnected to shore power and doesn't record shore power time (which is what I stated before) then why is it still recording time?
generator
