Old 05-04-2014, 09:10 AM   #1
Generator not fully powering everything
For some reason the generator is not powering the rear AC or the microwave. The inside breaker is fine and one if the two 30 amp breakers on the gen is tripped and won't reset. Everything works great on shore power. Any suggestions?
Preadus is offline   Reply With Quote
Old 05-04-2014, 10:01 AM   #2
Iggy's Avatar
With the generator off and no shore power will the generator break reset?
Then the breaker is bad on the generator.
Iggy is online now   Reply With Quote
Old 05-04-2014, 10:04 AM   #3
The breaker will not reset even when everything is off. Do you know where to get that breaker. Camping world?
Old 05-04-2014, 12:34 PM   #4
Newellri's Avatar
I had a similar problem and had to replace the breaker on the genny.
Newellri is offline   Reply With Quote
Old 05-04-2014, 04:40 PM   #5
GABoy's Avatar
Make sure the electric water heater is turned off. If this is on when we run off generator only it will trip the breaker for the rear a/c and micro. Aparrently on same circuit. Run water heater on gas when dry camp. If not that need breaker.
Tracy
GABoy is offline   Reply With Quote
Old 05-06-2014, 12:43 PM   #6
Freds342's Avatar
E-Bay has a jillion RV breakers at pretty fair prices.
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
Freds342 is offline   Reply With Quote
Old 05-15-2014, 11:02 AM   #7
I am having the same problem. Just picked up our 2015 351DS on Friday and when we have the generator on we can't use both a/c units. I was thinking that the fridge was pulling too much power so I turned it off (not working right now, going in for service today). That didn't help though.
sdowning is offline   Reply With Quote
Old 05-15-2014, 11:23 AM   #8
Just checked, not the water heater. Can't get the cover off the generator so I will have service look when we take it in.
Old 05-15-2014, 11:25 AM   #9
Swap the circuit breakers around. If the problem moves to the other side then you have a bad CB.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 05-15-2014, 11:27 AM   #10
Pull the cover from the top. It snaps in place.
generator, power
