Old 01-10-2015, 10:20 AM   #1
Generator Oil Change
Just tried to order oil, air and fuel filters from Camping World , 4 to 6 weeks for delivery and & $27 shipping !!!!! No thanks ! Stuff not available locally, got all from Amazon at a good price and FREE shipping. All OEM parts !
rdhodges is offline   Reply With Quote
Old 01-10-2015, 10:46 AM   #2
Tx_Rider's Avatar
Yep, I ordered Onan oil filters Wednesday and had the friday night. OEM, from Amazon. I will purchase oil locally, no need for "OEM" specific oil.
2015 Thunderbolt XLR 340X12HP
2019 Ford F350 KR, 6.7, CC, LB with B&W Companion
US Army Retired
Tx_Rider is offline   Reply With Quote
Old 01-10-2015, 03:55 PM   #3
Dijoeboss's Avatar
I pick up all my generator needs at a local Cummins repair facility, hadn't really ever thought about Amazon for that.... Good info to know!
2013 Georgetown XL 350
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Dijoeboss is offline   Reply With Quote
Old 03-31-2015, 02:30 PM   #4
Looking for some pros and cons, my generator will be due for an oil change soon. Has anybody ever used a NAPA filter? I have a store a few minutes from my home and they can cross reference their NAPA Gold filter with the Cummins/Onan number.
bmurph44 is offline   Reply With Quote
Old 03-31-2015, 04:41 PM   #5
Freds342's Avatar
NAPA Gold is all I've been using for 10 years and over 800 hours. I use Mobil-1 Syn, and change at 150 hours.
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
Freds342 is offline   Reply With Quote
Old 03-31-2015, 06:20 PM   #6
Thanks Fred that's what I'm looking for, they sure aren't cheap at $14.50.
Old 03-31-2015, 07:31 PM   #7
i have been using OEM filters and royal purple....but i think any good brand synthetic oil will do the trick...
2014 Georgetown XL 350TS
2014 Jeep Wrangler Rubicon Unlimited
Front & Rear Roadmaster Sway Bars
Koni Shocks
Front and Rear Sumo Springs Jounce Replacement
willingtonpaul is offline   Reply With Quote
Old 04-11-2015, 08:23 AM   #8
For my area temps range usage the book recommends straight 30 weight oil but you can't get that in synthetic...Any ideas or should I use regular oil?
Old 04-11-2015, 12:38 PM   #9
jsutherl's Avatar
Same here. I'm using Royal Purple and OEM filters from Amazon. Using Royal Purple because they make that stuff in pretty much every weight you can think of. Including all the weights called for by the genset, even single weight Royal purple is available.
http://www.royalpurpleconsumer.com/a...g_20140107.pdf
2008 Georgetown SE 350DS BunkHouse
jsutherl is offline   Reply With Quote
Old 04-14-2015, 12:31 AM   #10
Cornelius's Avatar
The NAPA Gold filter for the Onan 5500 Generator is actually made by Wix, and is available as a Wix brand filter at O'Reilly Auto Parts stores. Amazon usually has the Onan OEM filter in stock and at a slightly lower price than NAPA or O'Reilly.
I have used all three, never any problems.
Onan # 122-0836
NAPA # 7398
Wix # 57398
2010 Georgetown 373
2013 Jeep Wrangler
Cornelius is offline   Reply With Quote
Old 04-14-2015, 12:59 AM   #11
Crockett's Avatar
Air cooled engines are hard on multi-viscosity oils. Forget about that with synthetics, because they are much more tolerant of heat. Plus with 150 hour change intervals over the standard 50 hours with conventional oil, you'll actually save money with synthetics if you have no leaks.
Crockett is offline   Reply With Quote
Old 04-28-2015, 02:01 PM   #12
siskom's Avatar
generator
If you have a O'reillys Auto parts close they carry WIX brand oil filters for the generator and use Mobile 1 you won't ever have a problem. I use both in a hard running Mercruiser marine engine that runs high RPM;s for hours still like new. Now also using in Motor home engine.
siskom is offline   Reply With Quote
generator
