Old 06-22-2015, 05:05 AM   #1
generator problems
I have a georgetown 351 with a 5.5 onan generator. On this trip the generator would not run both a/c at once even when turning them on after one has been running for a while. also the could not use the microwave and a/c at the same time. my last rv had a 4 kw it only had one a/c but i could use everything without tripping breakers. In the past the generator would run all these things at once what could be wrong with it?
ndb767 is offline   Reply With Quote
Old 06-22-2015, 05:10 AM   #2
fonzie's Avatar
Make sure your water heater is on propane only and if you have a residential refrigerator that adds to the amps draw on generator......
Fonzie
Old 06-22-2015, 05:51 PM   #3
Dijoeboss's Avatar
I've had the same issue since new on my 2013 351 XL..... 15K miles, not fixed yet....
2013 Georgetown XL 350
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Dijoeboss is offline   Reply With Quote
Old 06-22-2015, 05:53 PM   #4
jergeod's Avatar
Look at the front of the genny once you take the cover off there is two breakers make sure they are both on and not tripped.
George & Jerri
06 GT 340 TSSE
USMC
jergeod is offline   Reply With Quote
Old 06-24-2015, 09:41 AM   #5
I Break Everything
mikel68's Avatar
Check your breakers. Not for the fact they maybe tripped, but if there's any kind of loose of vibrating wire it could cause a trip. Our last one had to have the entire breaker box replaced. It tripped with one A/C and other issues. After the box was replaced we never had a problem again. But that was just our problem.
2015 Georgetown Forest River 351DS MH
2008 Keystone Cougar 293SAB 5th Wheel
2007 Jay Flight 30.5RLS 5th Wheel
2006 Jay Flight 29BHS TT
mikel68 is offline   Reply With Quote
Old 06-24-2015, 10:23 AM   #6
Dijoeboss's Avatar
generator problems
On mine, it's not tripping the breakers on the generator or at the breaker panel inside, the transfer switch disengages. And can't pull back in because of the load of the a/c units. Have to turn off the a/c's, let transfer switch pull back in and then turn a/c back on, do this every time you hit a bump on the highway for 885 miles in one day and it's gets beyond old!!!!
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Old 06-24-2015, 03:51 PM   #7
jergeod's Avatar
Then it is time for a transfer switch I guess unless someone can come up with a reason this is doing this other than a bad switch.
George & Jerri
06 GT 340 TSSE
USMC
Old 06-24-2015, 04:23 PM   #8
Dijoeboss's Avatar
It's had 2 already... The orginal one from the factory and I replaced it with a new one from Furrion that they sent me direct.
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Old 06-24-2015, 04:53 PM   #9
Our issue was the genny would turn itself off after about 30 minutes - it just spent a week at Cummins and they couldn't make it turn off (micro, both AC going was still fine)
Had them change the oil, and filters(oil,fuel & air) just since it was in for the work, and it was fine on the way home.
True test will be on Friday when we head out camping......
2015 Georgetown 351DS
2016 Jeep Wrangler Unlimited Sahara
Chris, Garren (humans)
Edgar & Carlos (felines)
RIP Sophie, the sweetest cat ever.
ChrisAndGarren is offline   Reply With Quote
Old 06-24-2015, 06:13 PM   #10
Iggy's Avatar
Now you do know that the amperage doesn't change on the AC or go down after startup. These are not house AC units with compressors.
They pull constant amps so turning one on then another doesn't really do much.
My 15,000 BTU unit pulls about 19 amps, My 13,500 pull 17 amps and that's 36 amps. My 5500 Onan has a max amps of 46 amp on the label.
So a microwave could put it over as mine is pulls 1600 watts which is 13.3 amps at 120 volts.
So that totals 49 amps and will trip your generator breaker.
I just don't run everything as once which solves any overloads.
Iggy is online now   Reply With Quote
generator
