Old 05-02-2015, 02:55 PM   #11
Got oil, it was bone dry.
Starts right up but still no electricity in the couch???
2008 Georgetown 370ts XL
E-man is offline   Reply With Quote
Old 05-02-2015, 03:50 PM   #12
fonzie's Avatar
Check main breaker on generator and then auto-transfer switch......
Fonzie
Old 05-02-2015, 04:34 PM   #13
Okay breakers good so it looks like my transfer switch may be it.
Old 05-02-2015, 05:53 PM   #14
This may be a long shot but are the A/C's turned off?
Also some transfer switches make a "clucking" sound when they try to engage after 30 seconds or so from starting the generator. Do you hear anything like that?
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is online now   Reply With Quote
Old 05-02-2015, 06:16 PM   #15
All is off. I don't think it makes a clucking noise.
Not sure if they had anything to do with it but when we had the heater on the floor got very very hot this morning, like I said not sure if that has anything to do with it.
Old 05-02-2015, 06:44 PM   #16
When you say floor heater are you referring to the propane furnace or is it an electrical 110 volt plug in heater?
If you are not comfortable working with electricity then there is not much else you can do. AND DON'T IF YOU ARE NOT COMFORTABLE.
Sometimes there are small fuses inside the transfer switch box but there again you will be next to dangerous high voltage when plugged in to shore power or with the generator running.
2008 Honda CR-V
Old 05-02-2015, 06:51 PM   #17
After thinking about your heater getting very very hot, it could mean your generator is putting out too much voltage. That could also mess up you inverter inside the generator keeping it from generating electricity.
2008 Honda CR-V
Old 05-02-2015, 06:55 PM   #18
Wrapperman the heater works on gas so no load should be on it except for some battery power to run it.
Not too comfortable around electricity so we will wait for the RV guy to take a look at it Monday, unless I could check the fuses now while dry camping.
Old 05-02-2015, 07:04 PM   #19
If the generator is NOT running then you can look inside the transfer switch box to see if there are any fuses that went bad. It's worth a shot.
Cheaper than a repair man.
2008 Honda CR-V
Old 05-02-2015, 07:44 PM   #20
I'm with you I would love for us to figure it out.
The generator runs every time. The problem is nothing in the RV comes on.
generator, power
