Old 05-02-2015, 08:28 PM   #21
Just make sure the generator is OFF
The coach batteries will not hurt you unless you touch a positive to a negative with your pliers or screw driver. Remember on the batteries the negative is any metal on the coach.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 05-03-2015, 10:45 AM   #22
Okay started looking but can't find the transfer switch. Is it under the stairs? I also see a box that is connected to the shore line but can't see how to remove cover?
2008 Georgetown 370ts XL
E-man is offline   Reply With Quote
Old 05-03-2015, 11:47 AM   #23
fonzie's Avatar
Here is typical transfer switch, it will have three seperate cables going into it.....
Name:	transfer switch automatic.jpg
Fonzie
Old 05-03-2015, 12:05 PM   #24
Mikegjax's Avatar
When you checked your genset breaker you should turn it completely off to reset and then on. May not be the issue, but just a thought.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 05-03-2015, 01:48 PM   #25
Yep on the generator breakers but still no go.
Where would they Put the transfer switch?
Old 05-03-2015, 02:32 PM   #26
2014 XLR 27HFS
I can't tell you where on your unit, but you should be able to follow the shore power line and the generator power line - they will meet up at the transfer switch.
Dave & Audrey
dave961 is offline   Reply With Quote
Old 05-03-2015, 02:33 PM   #27
Okay just found what I think is the transfer switch but it appears that it has a small water leak going into it.
When I try to take the cover off with everything shutdown I got some water leaking into my hands. There was a paper towel sitting there and it's socked. Since the rear toilet and sink are directly above it (genius design) I think it's one of them.
Can't figure out how to take the cove off to take a closer look, but I see a couple of screws so I will try it out.
Name:	ImageUploadedByForest River Forums1430681617.443252.jpg
Old 05-03-2015, 02:46 PM   #28
Originally Posted by George_Lisa View Post
Top it up and you should be good ,if you unplug the sensor you can run it just to see if thats the problem.
How about you just top off the oil as needed, rather than run the generator, knowing its low on oil and go with what the design engineers wired it for that specific reason.
Sounds like you might have fried the transfer switch. Maybe letting it dry out will give it new life, but pc boards really don't like water much. Good luck.
Old 05-03-2015, 02:50 PM   #29
fonzie's Avatar
Yes that's it, once you have open take another picture and post.
Fonzie
Old 05-03-2015, 03:09 PM   #30
IClick image for larger version
Name:	ImageUploadedByForest River Forums1430683733.804810.jpg
Okay here it is I see some dampness but not water!
generator, power
