Old 05-02-2015, 11:06 AM   #1
Generator stopped powering RV
Hello All,
It's me again. We are out and had the generator on for about 6 hours yesterday and all went well.
This morning I went to turn it on and it would stop after 1 or 2 minutes.
Then we tried a 3rd time it ran but nothing is on in the motorhome, what should I check?
2008 Georgetown 370ts XL
E-man is offline   Reply With Quote
Old 05-02-2015, 11:11 AM   #2
George & Lisa
George_Lisa's Avatar
Hi there ,check the engine oil level if its down it will trigger the low oil shut off switch.
2006 R-Vision 18' Bantam Flier
2005 Chev Blazer 5speed
George & Lisa
Nights Camped- 2015.... 25 nights
Nights Camped- 2016.... 2 so far
George_Lisa is offline   Reply With Quote
Old 05-02-2015, 11:15 AM   #3
See if the fuses tripped on the generator.
Can you hear the transfer box engaging?
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 05-02-2015, 11:25 AM   #4
Okay, fuses looks good but the oil look really low.
If it's a guardian 6500 watts.
Old 05-02-2015, 11:25 AM   #5
What type of oil does it take?
Old 05-02-2015, 11:27 AM   #6
George & Lisa
Top it up and you should be good ,if you unplug the sensor you can run it just to see if thats the problem.
George & Lisa
Old 05-02-2015, 12:19 PM   #7
Ok going to get some oil and will top it off and let you know.
Old 05-02-2015, 12:21 PM   #8
Ford Idaho's Avatar
If it is low perhaps it is time for a service, do you know if it has an oil filter?
Old 05-02-2015, 12:42 PM   #9
I will have our RV guy to do an overall check on the RV before our big Yellowstone trip.
Not sure Where the filer is!
Old 05-02-2015, 12:44 PM   #10
Scubanut's Avatar
I only use my generator when hunting at it runs about 8 hours a day for 6 days. Even when new it would run low on oil.
Scubanut is offline   Reply With Quote
Old 05-02-2015, 02:55 PM   #11
Got oil, it was bone dry.
Starts right up but still no electricity in the couch???
Old 05-02-2015, 03:50 PM   #12
fonzie's Avatar
Check main breaker on generator and then auto-transfer switch......
Fonzie
Old 05-02-2015, 04:34 PM   #13
Okay breakers good so it looks like my transfer switch may be it.
Old 05-02-2015, 05:53 PM   #14
This may be a long shot but are the A/C's turned off?
Also some transfer switches make a "clucking" sound when they try to engage after 30 seconds or so from starting the generator. Do you hear anything like that?
2008 Honda CR-V
Old 05-02-2015, 06:16 PM   #15
All is off. I don't think it makes a clucking noise.
Not sure if they had anything to do with it but when we had the heater on the floor got very very hot this morning, like I said not sure if that has anything to do with it.
Old 05-02-2015, 06:44 PM   #16
When you say floor heater are you referring to the propane furnace or is it an electrical 110 volt plug in heater?
If you are not comfortable working with electricity then there is not much else you can do. AND DON'T IF YOU ARE NOT COMFORTABLE.
Sometimes there are small fuses inside the transfer switch box but there again you will be next to dangerous high voltage when plugged in to shore power or with the generator running.
2008 Honda CR-V
Old 05-02-2015, 06:51 PM   #17
After thinking about your heater getting very very hot, it could mean your generator is putting out too much voltage. That could also mess up you inverter inside the generator keeping it from generating electricity.
2008 Honda CR-V
Old 05-02-2015, 06:55 PM   #18
Wrapperman the heater works on gas so no load should be on it except for some battery power to run it.
Not too comfortable around electricity so we will wait for the RV guy to take a look at it Monday, unless I could check the fuses now while dry camping.
Old 05-02-2015, 07:04 PM   #19
If the generator is NOT running then you can look inside the transfer switch box to see if there are any fuses that went bad. It's worth a shot.
Cheaper than a repair man.
2008 Honda CR-V
Old 05-02-2015, 07:44 PM   #20
I'm with you I would love for us to figure it out.
The generator runs every time. The problem is nothing in the RV comes on.
generator, power
