Old 03-04-2015, 06:06 PM   #11
Thanks for all of the input. I changed the oil and filter when I first found it to be low, have run it about 15 more hours and the level is staying consistent.
Gladly no damage done, I will sure check things from the factory before running in the future
Jim G is offline   Reply With Quote
Old 03-04-2015, 07:22 PM   #12
Pixelbum1's Avatar
Excellent! You'll be fine with the maintenance routine on it. Is really hard to damage these tough engines, really, even when a bit low as is perceived by us. Don't forget to change the oil\filter at the 20 hr. mark which normally is the first time but you're ahead of the curve. Good luck then.
Pixelbum1 is offline   Reply With Quote
Old 03-04-2015, 07:36 PM   #13
Freds342's Avatar
It also helps to pre-charge the filter, filling it with oil prior to installing. It takes a minute and saves ten!
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
Freds342 is offline   Reply With Quote
