Old 08-01-2016, 05:18 PM   #11
We had this problem last year - took the coach to the Onan-Cummins dealer and they played with it for a week and couldn't replicate the problem. I had them do a full oil change (since we were there and all) and it's worked fine ever since. When I was doing my research, there was a lot of speculation about the fuel filter getting clogged as we were driving - but never got anything definitive.
Kinda frustrating, but it works now so okay......
Garren
2015 Georgetown 351DS
2016 Jeep Wrangler Unlimited Sahara
Chris, Garren (humans)
Edgar & Carlos (felines)
RIP Sophie, the sweetest cat ever.
ChrisAndGarren is offline   Reply With Quote
Old 08-01-2016, 05:28 PM   #12
Here's the link to our thread from last year.....maybe will give you some ideas?
Onan Generator Issue - 5500
Old 08-01-2016, 05:31 PM   #13
Iwannacamp's Avatar
X3 on the oil. Use an OEM spec synthetic oil. It will reduce the operating temperature and save fuel at the same time.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Days camped 2016 8 2017 1
Iwannacamp is online now   Reply With Quote
Old 08-01-2016, 05:34 PM   #14
Had same problem. My diesel gen supplied by electric fuel pump so--NO vapor lock, that was a myth of the 50's. Took it to a Gen shop. Radiator had so much dust and dirt in the fins it couldn't cool in high heat. Cleaned the fins with engine de greaser, water, and air. Problem solved. May work for you, worth a try and cheap.
pdqparalegal1 is offline   Reply With Quote
Old 08-02-2016, 08:10 AM   #15
gmann55's Avatar
Sorted fuel pump
I had trouble for a year before I replaced the fuel pump! Was told to replace Cummings fuel pump with airtex pump! No more problems! This is on an Onan 5500 watt gas generator ! Good luck! Travel safely!
gmann55 is offline   Reply With Quote
