Old 07-31-2016, 04:11 PM   #1
Genset Shutting Down In Heat
We traveled from Florida to Tennessee this month and the weather was so hot we had to run the Genset (Onan) late in the day so the cabin AC could keep our passengers cool.
We had a problem with the Genset in that it kept shutting down at odd times. For instance, if it was running at a rest stop, as soon as we got back out on the highway, it would cut out and would not restart for a while.
Has anyone else had this happen with their Genset? I am wondering if it could be vapor lock since everything downstream of the Ford engine got really hot.
hikerjohn7 is offline   Reply With Quote
Old 07-31-2016, 04:25 PM   #2
ilmor's Avatar
I've read about others that had this problem, and it was apparently vapor lock. They added a vent to the generator thru the hatch so that cooler air is fed to it. I think Forest River even provided some to customers.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 07-31-2016, 04:44 PM   #3
World Wide Wanderer
wahoonc's Avatar
Possibly a vapor lock or overheat situation. I had this happen to ours this past weekend, we stopped for a short doggy break and to hit up an ATM. It shut off right before we were ready to roll again. It started back up a couple of miles later. One thing is to make sure you have plenty of oil and consider going to a heavier duty oil. I use 30 wt in mine during the hotter seasons and it seems to help. These things run HOT, I have brown grass spots at home where I had it cranked up to run for a bit and was off the gravel parking pad. When you have temps in the 90's and you are on blacktop, it is going to be brutal for the generator. They are air cooled, and with 140+ air you are going to get limited cooling.
I too have heard about the added vents from FR but have yet to see a comparison picture.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 07-31-2016, 07:14 PM   #4
RVnut's Avatar
I will add that we had this happen a few times with our Generac on our last MH and it was due to a thermo switch that protected the generator when it got to hot from the temp of road and air.. I replace the switch and problem stopped.. I dont know if Onan has this switch too
364 Georgetown 2016
in Montana
RVnut is offline   Reply With Quote
Old 07-31-2016, 09:24 PM   #5
Is the generator shutting off or just the AC's?
2016 364TS
Kevin M. is offline   Reply With Quote
Old 08-01-2016, 09:22 AM   #6
kenandterry's Avatar
Kevin M......
The problem discussed here is with the generator shutting down.
I have the same problem with a Generac generator only when driving under hot conditions. When we're parked the genny runs fine. I suspect it's the increased heat coming up from the road pavement combined with the fuel sloshing around, possibly vapour lock of a simple carburetor design, or the low oil sensor tripping a shut down from the genny oil level sloshing around while driving.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 08-01-2016, 09:35 AM   #7
NCCoachMan's Avatar
Generator shutting off sounds like vapor lock.
Generator running but no power to coach sounds like transfer switch problem.
There are several conversations about these issues here. I wish we had some definitive answers.
NCCoachMan is offline   Reply With Quote
Old 08-01-2016, 10:31 AM   #8
Genset Cut-Off
Good feedbacks. Thanks.
I guess I will do some more research on the mentioned cut-off features in my Onan.
Old 08-01-2016, 02:20 PM   #9
Fuel Pump
I just had this problem with mine and it was the fuel pump. Would run fine for a period of time and then shutoff. Thought it was temp related but then read about vapor lock due to low fuel pressure. Replaced it and both filters and runs great now. May not be your problem but have seen numerous post here and other blogs that indicate it is a pretty common problem.
kenlea98 is offline   Reply With Quote
Old 08-01-2016, 03:41 PM   #10
gizmo98's Avatar
I have 20 hours on my onan generator 4000 watt and a mechanic friend recommends replacing the oil with full synthetic swears by it and is great for changes in operating temperatures
Rob & Elizabeth Sweeney
Having fun in our Forester Gump (2015 3051S forester)
gizmo98 is offline   Reply With Quote
