Old 09-12-2015, 12:09 PM   #1
Georgetown 2007 349 A/C questions
Can I run both airconditioners off of the generator while traveling for long period of time?
How large is the gas tank in this unit 349?
Thomasbogan is offline   Reply With Quote
Old 09-12-2015, 04:34 PM   #2
Iggy's Avatar
You left out a few things.
What size is your generator?
How many hours on the generator?
Has the oil and filter been replaced recently?
If you have high hours has the spark plugs been checked or replaced?
What size are the AC units?
I believe your gas tank is 75 gallons back in 2007.
Yes if you have a 5,500 watt generator you should easily run both AC units on generator.
Remember the generator will not run if you get below 1/4 of a tank of gas.
This is designed to have fuel for the engine in the MH to get to a gas station. lol
I found and attached the Ford book on the 2007 F-53 bare chassis you have.
georgetown
