Old 07-04-2014, 06:34 PM   #1
georgetown 328 power to plug ins from inverter
Is there someway to get power to plug ins from inverter when not plugged in or power from generator?
JohnGray is offline   Reply With Quote
Old 07-05-2014, 08:32 AM   #2
What are you trying to power and what size is your inverter?
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 07-05-2014, 08:59 AM   #3
Dave_Monica's Avatar
Isn't your inverter (changes 12V DC to 120V AC) wired up from your battery bank?
Dave
Old 07-06-2014, 08:39 AM   #4
Solar?
dayami is offline   Reply With Quote
Old 07-06-2014, 08:52 AM   #5
VinceU's Avatar
There is but wouldn't last very long. An AC load drawing 5 amps 120 VAC would need about 50 amps steady draw from the battery, at that rate maybe 1 hour of full power.
Old 07-06-2014, 01:43 PM   #6
I want to run the TV and power some plug ins.
Old 07-06-2014, 02:14 PM   #7
If you have one of the prowatt inverters it will have two 110v outputs. You could run an extension cord to your TV. You have to keep in mind that the inverter is just big enough to run your fridge.
We fire up the generator anytime we want to watch TV, run the roof AC units or use anything else.
georgetown, inverter, power
