Old 06-05-2012, 06:30 AM   #41
Navion IQ 24V
My steps broke 3 weeks ago, main pivot bolt sheared off. Removed steps & found that it was tack welded to keep it from backing out. These are made by LCI . I will be picking up my replacement steps this Friday. Sounds like an all to common issue. Its not a field repairable item (until the warranty runs out). We have only been on 1 trip with it & fortunately it broke at my house. It did not just collapse but got real spongy when extended that's what made me look underneath & see that the bolt was cocked.
Sold 2012 Georgetown 350F Gasser
Navion IQ 24V
Wildhog56 is offline   Reply With Quote
Old 06-05-2012, 09:20 PM   #42
Iggy's Avatar
Did you contact your dealer or Lippert or Forest River to get replacement steps?
Iggy is online now   Reply With Quote
Old 06-05-2012, 09:30 PM   #43
Navion IQ 24V
I went through the dealer to get the replacement steps. No argument from them as a matter of fact they ordered the new steps without even seeing the broken ones. Went off my word about what bolt had broken. When the new set arrives this Friday I will go swap them out. Thats a 700 dollar set of steps with no argument fom any of the involved parties, so It must be a common issue.
Navion IQ 24V
Old 06-06-2012, 08:30 AM   #44
Could all this be prevended if lubed eveytime you use your MH?? just my 2cents.but I will check mine also just in case want no proplems on my trip to Arizona starting next week. Be SAVE
George
2012 Georgetowne 280
Towing a Saturn 2001 LW 200
RED Baron is offline   Reply With Quote
Old 06-06-2012, 09:50 AM   #45
Navion IQ 24V
George
That was one of the 1st things done to the unit when I purchased it, I crawled under it with my creeper , can of silicone & grease gun. Lubed it from front to back & eyeballed everything , looking for anything that may be suspect. The steps got the most attention since this my 1st unit with electric steps. I just moved over from the 5th wheel group for the past 10 years.
Navion IQ 24V
Old 06-06-2012, 01:36 PM   #46
Iggy's Avatar
Loose bracket found
Here is a picture of my step underside. I found a loose bolt and bracket on the main arm. Can anyone tellme what is it for and what position should it be in before I tighten.
See picture and red circle.
Old 06-06-2012, 02:31 PM   #47
Navion IQ 24V
I noticed that on mine to, I did not notice of mine was loose though. Its not used to adjust the cams or the throw on the steps. I will be home in the morning & re-look at my old ones since they are off the coach. I looked at the set up instructions & it makes no reference to it. Maybe someone else on here will know. In the mean time I will continue to see what i can find out.
Navion IQ 24V
Old 06-06-2012, 03:18 PM   #48
Iggy's Avatar
I also found this document on Lippert s website about the step bolt that keep breaking. Not sure if it true or not but more information about replacing the hex nut bolt.
Gear plate and bolt replacement
Old 06-06-2012, 04:23 PM   #49
Send a message via Skype™ to Falcon35
Thank's Iggy:
Two more pages for my file.
2012 Georgetown 378TS Fire Mist
2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Protect-A-Tow
Falcon35 is offline   Reply With Quote
Old 06-06-2012, 04:48 PM   #50
Have you considered using a Gr 8 bolt? They are a lot stronger than a Gr 2 or Gr 5. A Gr 8 bolt will have 6 hash marks on the head, a 5 will have 3 and a 2 will have none.
