Old 07-22-2013, 05:41 PM   #71
After you fix your bolt you may want to carry a couple of blocks of wood with you and put them under your steps when camped.It makes them very stable and takes the strain off the bolt.
johnnypal is offline   Reply With Quote
Old 07-23-2013, 11:41 AM   #72
Falcon35's example of the bolt needed is for a two step set up. I have the Lippert three step set up and wouldn't mind ordering a couple of spare bolts to have on hand as this seems to be the most common problem. Does anyone know which bolt is needed for the three step? Thanks in advance!
sherman12
2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 07-23-2013, 12:19 PM   #73
Recycling electrons from this thread: Day 3 of 16 - Heading to DC
Chris
Cumming, GA
2013 Georgetown 351DSF
http://curban.smugmug.com/Urban-Fami...rgetown-351DSF
ChrisMSNT is offline   Reply With Quote
Old 07-23-2013, 02:08 PM   #74
Send a message via Skype™ to Falcon35
If you are not sure get down under your step and look up and you will see a label with the part # and everything you will need. I took my camera and took a picture. I then phoned Lippert and talked to someone in parts. They were very helpful. With the part # for the step you can't go wrong.
2012 Georgetown 378TS Fire Mist
2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Protect-A-Tow
Falcon35 is offline   Reply With Quote
Old 07-23-2013, 02:10 PM   #75
In the link above, I put the direct link to the Lippert PDF for part numbers and the stair components. It should be all inclusive within the thread above. :-)
Chris
Cumming, GA
Old 07-23-2013, 02:43 PM   #76
Thanks guys!
sherman12
