Old 10-24-2013, 05:55 PM   #1
jergeod's Avatar
Georgetown 340TS
Found a 2006 340TS for a very reasonable price and was wondering if there is anything I need a heads up on about this model. Has the V10 but not sure which HP.
jergeod is offline   Reply With Quote
Old 10-25-2013, 05:42 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
2006 Georgetown Brochure.pdf
2006 Ford F53 Body Builders Layout Guide.pdf
Welcome to the Forums. Here are the 2006 Brochures with the specifications.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 10-25-2013, 12:07 PM   #3
Anacortesians
We have an '02 325 that we got from the original owners in 201. We're reasonably comfortable with it. Construction of some of the house bit could be a lot better engineered, but the engine and Chassis are much better than our old Class C with a 460.
Frank and Eileen
No longer RVers or FR owners
Old 10-25-2013, 02:33 PM   #4
jergeod's Avatar
I have been doing a ton of research on the 06 340TS and it seems like a decent unit. Still can't find out the HP for 06 if it is 310 or 362 and the trans if it is a 4-5or 6 speed. Thank you both for the info you have given me it has been helpful.
George
Old 10-27-2013, 03:14 PM   #5
cfsoistman's Avatar
Ford F53 2006 Info.pdf
Depending on when it was built, it may be built on a 2005 Chassis. If you can get the Vin number you'll know for sure. If it is built on a 2006 chassis then this pdf will be what you're looking for.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 10-27-2013, 06:59 PM   #6
jergeod's Avatar
cfsoistman, I have to thank you for all the info you supplied, have no idea where you found it all but thanks. Took the plunge Saturday but won't get it for a couple weeks they are going to have Ford do some rear axle work, needs a new pinion brg and seal. Thanks again, you have been a big help.
Now do you have any idea how to break down the serial number?
Old 10-28-2013, 11:03 AM   #7
jergeod's Avatar
Found the answer to that one.
georgetown
