Old 07-29-2016, 04:22 PM   #1
Georgetown 351DS Questions...
I have a few questions regarding my Georgetown 351DS...
Are there tire sensors to let you know when tires are low?
How do you check the tire pressure on the inside back tires? Tough to get to the valve on the inside tires?
Is there an Emergency start if your batteries go out? (Hasn't happened, just want to be ready... I make a sheet for any issues that may arise)
Electric Jacks... is there a manual up and down? If you had any issues, how do you get them up if the electric won't work?
Hills... keep on drive whether you have a tow vehicle or not?
Awning is electric... is there a manual to bring in or out in case electric issues?
Electric Slides... how hard is it to get to the manual slide area above the kitchen slide out? And do you need a special tool to bring it in or out?
Thanks for taking the time.
philthy99 is offline   Reply With Quote
Old 07-29-2016, 09:37 PM   #2
Iggy's Avatar
philthy questions
You should have valve extensions on your inner rear tires already>
If not contact your dealer.
Their are many after market tire pressure monitors on the market.
I have TST monitors for the past 4 years and work great.
You should have a switch on the left drivers console that is marked Battery Boost. If you push and holf this switch it will take house batteries and engine batteries together in case the engine battery gets low parked.
YES read the manual
Read the manual or call Lippert
????? Yes keep driving like you stole the motorhome.
Yes read the manual
Are they hydraulic or electric slides? Either way yes you can get access.
What year is your Georgetown?
2012 Georgetown XL - 378TS
Iggy is online now   Reply With Quote
Old 07-30-2016, 11:47 AM   #3
I have read the manual! (kinda don't like that when people say that)... not easy to understand, but since you have read the manual, you already know that.
georgetown
