Georgetown 351DS Questions...
Hi,
Have a few questions, on my Georgetown 364...
Ice Maker... how do I get that working? I have opened up the water under the sink and have checked the valve outside under RV... open as well?
Water Pump to use fresh water... do you just fill up the tank and turn on the water pump? And can you, should u use while driving?
Awning, can you strap this down so you down have a wind gust break it? And if you adjust the arms, do you have to put back to normal spot when you roll up?
Antenna booster... how do you know if it's working? I know there is a green light above the passenger seat compartment... if that's green is it working or do I need to hit another button? Seems like I'm having a tough time getting anything from the antenna?
Thanks for taking the time.
