Originally Posted by Iggy
If you think you have cable slide then it probably would be AccuSlide manufacturer. It is used for waredrobe slides and not room slides.
You never said what slide you are talking about. Are all your slides cable?
Here is a manual. Let me know if this is what you have.
If this is not what you have I have no idea. Why don't you take a few pictures and show us what you have.
Thanks Iggy I finally got confirmation from FR this week that they are indeed Accu Slides. Yes they are cable slides, both on the bedroom slide and living room slide. From reading the manual, I hope the Good Lord has mercy on me and I have no failures with the slide out. From what I can tell, you have to completely remove the Valance over the slide and use a flex shaft to turn the motor to retract it in case of a failure. I have looked and don't think I want to tackle this job.
In fact, I did not get the flex shaft when I picked up my coach in July. Since I did not know any better, I did not do a complete look through of the manuals and did not notice there was no manual. Hence, did not know about shaft. Called Accu-Slide and they say I have to go through a dealer to order one. What a bummer.
