Old 12-23-2013, 08:49 PM   #1
Sbryant's Avatar
Georgetown 360
Ok we are using our floor heater (propane) cause it's very cold - even down south Alabama. Heat comes out all the vents except the rear master bath. No heat coming out of the vent under the linen closet. Anybody else experience this problem?
Sbryant is offline   Reply With Quote
Old 12-24-2013, 02:40 PM   #2
Had the same problem you need to ballance the air coming out of the floor vents. close some of the vents down using the dampers on the floor vents . On our 360 we had no dampers on the vent by the passangers seat, so in the AM I place a cover over the vent that makes more heat go to the back of the RV and the back bath room. After we get moving around I remove the cover and leave the back Bath room Door open.
Dud360 is offline   Reply With Quote
Old 12-28-2013, 09:35 AM   #3
Heat to all the vents.
You can try a quick test - block all of the other vents and turn on the heater - if there is no heat at all to the register in the back bath then something is blocking it. Do not run the heat very long for the test. Don't forget to remove the blocks on the other vents.
In our 360 all the vents work - even the back bathroom. You should feel some heat. There may have been a problem at manufacture. The vent system uses a single duct running from front to back (the furnace is near the front, under the stove/oven). You may want to try removing the register and using a piece of wire (a coat hanger that has been straightened) feel if you are hitting something that is blocking the register. I found have found foam, wood pieces/sawdust, wire, and some strange looking glue when I cleaned out my ducts.
If you do not find anything obstructing the vent - go to the next vent in-line and do the same check. If still nothing, take it to the nearest dealer and ask them to check the run with a scope.
RobKat is offline   Reply With Quote
Old 12-28-2013, 11:01 AM   #4
Sbryant's Avatar
Our register in the master bath is wood? We can't figure out how to get it out. Is your's the same? So what's the removal clue?
Old 12-28-2013, 12:02 PM   #5
Ours is metal and has two screws - one at each end. The wooden register normally has 2 circular wood caps over the screws. Pop them off and you should see the screws.
Old 12-28-2013, 12:06 PM   #6
Sbryant's Avatar
Currently traveling. When we can check will let you know. That's for the tip.
Old 12-28-2013, 12:07 PM   #7
Sbryant's Avatar
That's should be thanks.
Old 03-09-2014, 05:38 PM   #8
Bought a small electric heater works great. No more cold bathroom.
georgetown
