Old 08-28-2015, 02:21 PM   #1
Georgetown 377 Brake/Directional Lights
Directional Lights and Brake Lights work fine so long as you don't do both at the same time. If you have the left or right directional light on and press the brake pedal the directional lights quit working. Can anyone help. 2013 Ford F-Series Super Duty Chassis.
beezereece is offline   Reply With Quote
Old 08-28-2015, 09:40 PM   #2
abjb's Avatar
Most chassis light (and camera) problems are caused be corroded bulb contacts or a corroded/broken/lose ground.
You need to check EVERY turn/clearance bulb, you'll probably find a few that don't work.
Get some contact cleaner and dielectric grease, clean and grease each bulb. Be careful when working on the ones mounted high it's a long way down.
Here are some links to threads that might help.
blinker won't work
Left turn signal lamp mystery
Problems with cameras
amber clearance lights
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 08-29-2015, 06:34 AM   #3
Good info, thanks. All bulbs involving the directional lights/brake lights are working. Did notice I have one clearance light (topside drivers side) out in the front and one clearance light (topside passenger side) out in the rear. Pulled them out but they are hardwired somewhere that I haven't found yet. If i disconnect plug under rear of RV front directional lights will work properly when brake is applied.
Old 08-29-2015, 06:39 AM   #4
waiter21's Avatar
As JB said, loosing a ground (broken wire) will do very weird things as the current now tries to find a new path to ground.
Question: Did it always do this or was it working ok and just started doing this?
Was any work done on the electrical system recently , i.e. hooking up TOAD lights.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 08-29-2015, 08:12 AM   #5
I am thinking the issue is a result of Crain RV in Little Rock Arkansas. When we traded our other Georgetown for this one they tore the wiring harness a part to get the lights to work on our TOAD. Guess i had better get up under the rear and do some wire tracing. I just don't remember if I had this issue when I left Little Rock. We were in Huntsville Alabama when I noticed the issue.
Old 08-30-2015, 06:05 AM   #6
waiter21's Avatar
I think you just found your problem....
ALSO - the problem you described, is this on the MH or the TOAD?
i.e. the MH lights are OK but the TOAD lights do what you described.
georgetown, light, brakes
