Old 03-26-2014, 10:49 AM   #1
Georgetown 378 LP Gas Reading
Took delivery in January LP gas full. Spent a couple nights in it and used some LP showed 3/4 full when done. MH was stored for about six weeks , was winterized and gas valve turned off at tank. Took it out this past weekend for a couple nights every thing worked as it should but the LP level at the control center shows full. Did it make gas ......?
rdhodges is offline   Reply With Quote
Old 03-26-2014, 10:52 AM   #2
fonzie's Avatar
Probably because now warmer temperature and gas (liquid) expands.
Fonzie
Old 03-26-2014, 12:46 PM   #3
I thought about that but temps have been about the same. Just can't believe as much LP as we have used it would still show full.
Old 03-26-2014, 06:21 PM   #4
Check that you werent topped off with a mix of propane and air. Had that happen a few years ago and the level would never get below 1/4 but the stove and hot water heater would start to falter. Best way to check is to open pressure relief valve at the tank and let some propane out by hand. If you get a nice fine mist then you are probably ok, but if you release and you see no mist then you have pure grade a air.
Watertown is offline   Reply With Quote
Old 03-27-2014, 10:23 AM   #5
Iggy's Avatar
OK. I admit it. I filled it up when you weren't looking.
Old 03-27-2014, 10:20 PM   #6
43D18's Avatar
I would take the control center reading with a grain of salt. I have never found that monitor to be overly accurate, on our Georgetown or in past coaches. Go outside and look at the gauge on the tank itself -that will be much more accurate.
As for being "topped off with a mix of propane and air" - I'm not sure how that could even happen? How would one do this?
I think the more likely explanation is an inaccurate reading at the control panel.
BTW, sort of related to this - we noticed our propane level dropping quite quickly over the holidays and discovered the regulator vent was leaking. Had to have the regulator replace at the dealer and now all is well.
Mike & Suz
2014 Georgetown 351
Pontiac Vibe toad
Buck & Patsy, the boston-mix guard dogs
43D18 is offline   Reply With Quote
Old 03-28-2014, 08:35 PM   #7
I don't recall seeing a gauge on the tank, I'll check ...........
Old 03-29-2014, 08:04 AM   #8
BillMFl's Avatar
I find that eating too many of my favorite Bush Baked Beans increases the gas supply.
BillMFl is offline   Reply With Quote
Old 03-29-2014, 04:26 PM   #9
Speaking of bush baked beans. Just north of pigeon forge tennessee is where they make them. They also have a museum , store an eatery. Well worth the time if you are around the area
Sent from my DROID BIONIC using Forest River Forums mobile app
jerryhowell is offline   Reply With Quote
Old 03-29-2014, 08:34 PM   #10
Thanks... The bean topic really helped with the question.......? As a newbie to the forum I see how this is going to work in the future. That your beans and ............
gas, georgetown
