Old 07-10-2013, 10:31 AM   #1
Georgetown 378 Squeaks
Yesterday I picked up my (new to me) 2011 model 378. On my first drive bringing it home we were getting a blood curdling schreech. I think it was coming from one of the slide outs. I am sure mine is not the only one that does this. Any ideas as to stopping this?
hlewis is offline   Reply With Quote
Old 07-10-2013, 02:50 PM   #2
kenandterry's Avatar
You didn't mention when and where this screech comes from.
Does it happen while you were driving down the road? Only when deploying or retracting a particular slide?
We need some more details in order to help you.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 07-10-2013, 03:07 PM   #3
Georgetown Squeeks
Sorry I forgot. The noises are happening while driving down the road. They sound like they are coming from a slide out. It is more pronouced when going over a bumpy area such as bridge seams.
Old 07-10-2013, 03:46 PM   #4
VinceU's Avatar
Slides may squeak, but they must be moving in or out to do so. I think your problem may lie with the Ford chassis. Spring pins, torsion bar bushings, all in the fwd end of the last of the coach length, near the doorway. If that's where the sound is, probably the reach suspension. Under your seats its maybe the front suspension. These joints do wear out and need to be checked every so often. The bumps clue me even more to check suspension. Enjoy your 378, great coach.
Old 07-10-2013, 06:26 PM   #5
abjb's Avatar
Check this thread.
2011 F53 and F59 suspension TSB
Although your 2011 is probably built on a 2010 chassis.
ab&jb
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 07-11-2013, 08:14 AM   #6
We have the same coach and had an almost constant schreech that we finally fixed by putting in strip of cardboard between the frame and glass on the fireplace. Sounds strange but take a look.
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 07-11-2013, 08:18 AM   #7
VinceU's Avatar
Forgot that one, great fix!
Old 07-21-2013, 09:06 PM   #8
intercept's Avatar
Same here
The final fix was to push the glass back a bit, masking tape the glass and metal frame and squeeze a bead of clear silicon adhesive between the glass and metal frame. Silence is golden
2012 Georgetown 378XL
Toad 07 Lexus RX350
intercept is offline   Reply With Quote
