Old 06-21-2015, 07:03 AM   #1
Cbretta's Avatar
Georgetown 378XL
Really need help please. I went to put slides in and it don't matter if I push the switch in or out all the big slides will do is go in and all the bedroom slide will do is go out, so now my two big slides are in and bedroom slide is out. I looked through the manual and can't figure out how to put in the slides manually. Any ideas would be appreciated.
Cbretta is offline   Reply With Quote
Old 06-21-2015, 07:07 AM   #2
LittlePM's Avatar
Reset the breakers under the steps
Pennie and Chuck, Mandi and Polly (the little dogs)
Your Hosts for BamaGanza 2017
2014 Georgetown XL378, 2013 Honda CR-V AWD Toad
Days Camped 2014 - 83, 2015 - 56, 2016 - 58, 2017 - 86
The Home of the FREE because of the BRAVE
LittlePM is offline   Reply With Quote
Old 06-21-2015, 07:14 AM   #3
Cbretta's Avatar
You can still hear the pump turning when button is pushed the slides will only go in one direction. Could this still be breakers?
Old 06-21-2015, 08:03 AM   #4
Tim & Lisa Trempert
Sounds like the valve or diverter is not working properly. Could be a dirty electrical connection on the valve. If you find your fluid reservoir you will see the manifold with all the valves. Try wiggling each wire/connection while someone presses the slide button.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 06-21-2015, 08:09 AM   #5
Cbretta's Avatar
Thanks. I will try all suggestions.
Old 06-21-2015, 08:18 AM   #6
abjb's Avatar
Here are a couple of threads with some good info, including the manual
Leveler georgetown 387
post #2, pg35 of the manual override instructions
Georgetown slide issue..
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
378xl, georgetown
