Old 02-24-2013, 09:31 PM   #11
Send a message via Skype™ to Falcon35
I have put a wedge under the leg on the low side. It still is not as stable as we would like but is level now. I will watch to see what you come up with in legs to make it more stable.
2012 Georgetown 378TS Fire Mist
2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Protect-A-Tow
Falcon35 is offline   Reply With Quote
Old 02-25-2013, 12:29 PM   #12
JimF's Avatar
Wow, glad we don't have these problems. I put a slide lock on ours to hole the top from sliding black and forth, works well and no wobbling at all, very stable little table. When we have it out for 4 people to dine it's quite stable. Never had a problem. Previously we had a 5 th wheel and this table is a huge improvement.
JimF, CWO, US Army Ret, 100% DAV
2011 Georgetown 378TS
2008 Dodge Caliber Toad
JimF is offline   Reply With Quote
Old 04-14-2013, 04:51 PM   #13
Uncle AL
Georgetown 378 Table
Finally took possession of our 378 and had the dealer replace the table. Not perfect, but better than the original. I spoke to Craig Fawcett at Georgetown and noted the many posting on the web regarding the table. He is in the process of testing a new prototype, which will be available later if approved. Not sure if they will do any replacing, but this model does look better.
Not sure if eating on the table while it is bolted down is a great idea. If you step on the portion of the slide that if floating, you could damage the particle board the table is attached to. Anyone have this concern?
Uncle Al
Uncle AL is offline   Reply With Quote
Old 04-15-2013, 08:30 AM   #14
(Not sure if eating on the table while it is bolted down is a great idea. If you step on the portion of the slide that if floating, you could damage the particle board the table is attached to. Anyone have this concern?)
Are you talking about eating at the table when the slide is in? Our slide floor is quite stable when the slide is out. But not so much when the slide is in. We don't use the table for anything when the slide is in. Anyway...I haven't had a chance to look at the table's stability issue, just need to get "round-to-it".
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 04-15-2013, 08:40 AM   #15
Fulltime family RVer
I have the same floating slide when it's in and was told by a factory rep to NOT step on it as damage could occur.
Of course, I don't have a Georgetown. I assume you're directions would be similar.
Old 04-15-2013, 08:51 PM   #16
VinceU's Avatar
I used a piece of 1/2" iron pipe, screwed into a "floor flange" about 2.5" diameter this end is placed on the floor inside of the slide floor. The other end is lightly wedged under the table on the inboard side right on the center hinge, using a plastic cap. Don't recall the length but I custom cut it to fit. The table will never be stable but this upward pressure tightens up the sliding pedestal grooves and steadies it dramatically while leveling. The assembly is painted with flat black paint and easily stowed for travel.
Old 04-16-2013, 08:46 PM   #17
A picture would be nice.
I need to do something like that.
2008 Honda Fit
Protect-A-Tow
Old 04-16-2013, 08:58 PM   #18
We often eat lunch at our table with the slide in when we are traveling. We did the same in fifth wheels that we had before we got the Georgetown. That is one of the pluses of having an RV. It's good eating a healthy meals rather then always eating in restaurants. It's not always possible to put out the slide in a rest stop.
2008 Honda Fit
Protect-A-Tow
Old 04-16-2013, 09:18 PM   #19
VinceU's Avatar
Sure, I'm heading over the next few days, I'll post couple of pics of pipe splint.
Old 04-19-2013, 03:35 PM   #20
VinceU's Avatar
Falcon and anyone else who's interested: Table is now quite steady and usable, no issues with dancing dishes.... Standard 12" pipe fittings.
Name:	leg on table.jpg
ID:	28399   Click image for larger version
ID:	28400   Click image for larger version
Name:	under table.jpg
