Old 04-27-2015, 08:18 PM   #11
May be air in the propane line......turn off the WH, and try to run your stove for a bit - that would pull the propane fastest (at least, it did when we had a similiar problem) and then retry the WH.
Garren
2015 Georgetown 351DS
2016 Jeep Wrangler Unlimited Sahara
Chris, Garren (humans)
Edgar & Carlos (felines)
RIP Sophie, the sweetest cat ever.
ChrisAndGarren is offline   Reply With Quote
Old 04-28-2015, 10:28 AM   #12
Fireman
Send a message via AIM to dutch
hot water tank
I had the same problem this spring when I tried ours on electric, if you can clean end of your ignitor with a green scratch it will clean it then try lighting it again.
2013 Georgetown XL 378
Toad 2012 Honda Civic
Dutch & Kathie & shitzue Buddy
US Air Force Retire SMS
dutch is offline   Reply With Quote
Old 04-28-2015, 01:13 PM   #13
abjb's Avatar
Originally Posted by moosey80203 View Post
Okay, I'm back again. We got the water running. Got rid of all the pink and the toilet flushed just fine. Our water tank is full as is our propane tank. I turned the hot water heater switch on, on the control panel and it fired right up. A minute or so later it went off. Now we can't get it to fire up again. Any suggestions my friends?
Just in case.
The water heater also works on shore and generator power.
HOPEFULLY the switch for elec was OFF if the tank was empty when you plugged into shore power.
The switch is in the lower right corner of the water heater.
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 04-28-2015, 01:53 PM   #14
Fireman
hot water tank
Sorry I mend to say starting on propane. Make sure you have water in your hot water tank before starting on elect or propane, run your faucet on the hot water side till you get all the air out and you have a nice steady flow of water then you know your hot water tank is filled. hope that helps.
