Old 04-27-2015, 01:57 PM   #1
Georgetown Antifreeze valve
Can someone help me? We have a 2012 Forrest River Georgetown. Trying to figure out where the anti freeze valve is so we can turn it and have water. The fresh water tank is full and you can here the pump. I read in a very old post that the valve is probably still in the winter position. Just don't know where that is at. Any help will be appreciated. CIndy
moosey80203 is offline   Reply With Quote
Old 04-27-2015, 03:30 PM   #2
fonzie's Avatar
It is usually where your water pump is....find water pump....
Fonzie
Old 04-27-2015, 03:39 PM   #3
Take a picture of your water cabinet, I think it is in the lower rh corner.
Old 04-27-2015, 03:49 PM   #4
Cyclone Rich's Avatar
This attachment has good pictures of the valves for winterizing. Just put them in the opposite positions of the instructions and you should be good to go.
Rig: 2012 Georgetown 351DS
Family: DW and 3 year old DD and newborn DD
Cyclone Rich is offline   Reply With Quote
Old 04-27-2015, 04:41 PM   #5
We noticed the 2 hoses both had a cap. Only one of ours has a cap. Could that be the problem? Maybe I have to make a run to the RV dealer. The clear cylinder is half full of anti freeze. Do we need to do anything with that? We didn't find a valve to switch on and off by the water pump itself. I'm sure this is such a simple thing if you know what you're doing. We're to ladies who are learning as we go. Really appreciate your help. CIndy
Old 04-27-2015, 04:43 PM   #6
To see if that is your problem, just put your thumb over the end and try it. If it works you know the problem.
Old 04-27-2015, 04:54 PM   #7
Oh duh? We're going out to try that.
Old 04-27-2015, 05:07 PM   #8
Thanks to all who helped. You all had a piece of the puzzle. The valve was right there in the lower right hand corner. Put a finger over the plug and had water coming out of the faucet. Now have to go to the RV store. You guys are awesome! Sure I'll have more questions in the future. Cindy
Old 04-27-2015, 05:23 PM   #9
Glad to help a little if we did.
Old 04-27-2015, 07:33 PM   #10
Okay, I'm back again. We got the water running. Got rid of all the pink and the toilet flushed just fine. Our water tank is full as is our propane tank. I turned the hot water heater switch on, on the control panel and it fired right up. A minute or so later it went off. Now we can't get it to fire up again. Any suggestions my friends?
