Old 10-08-2015, 06:18 PM   #11
We had an '07 Georgetown and camped with temp getting to -6 F. Turned on Arctic Pac, ran furnace, and used electric space heater. Invest in a heated water hose and make sure to disconnect sewer hose. No worries!
SkipnTerri is offline   Reply With Quote
Old 10-09-2015, 08:11 AM   #12
Originally Posted by RVCrazy View Post
We are looking at going on a camping trip in October/November. We are NOT going to be going if there is snow on the ground but the weather can get cool at night. Well maybe I should say below freezing at night. We will be staying in an RV park. Anyone have any suggestions on what we should or should not do during our stay? Should we invest in a heated water hose? What about the sewer hose? I am assuming that since we will be living in the motorhome and will have the heat on the plumbing etc should be fine. We will winterize immediately upon returning home!
We cover our water hose with a foam water heater insulation pipe.This prevents the water in the hose from freezing and cracking your hose. These are easy to store when not in use and pretty cheap.
cap2015 is offline   Reply With Quote
Old 10-09-2015, 08:40 AM   #13
Okay, I have a question from south Texas: What is this "freezing" phenomenon you guys are talking about? Please explain "freezing."
PS: it will be 90 deg F this afternoon here.
jrmartin67 is offline   Reply With Quote
Old 10-09-2015, 09:06 AM   #14
mark0224's Avatar
Never tried late camping but would take space heater to augment the furnace and make sure you have plenty of propane. You might want to leave some cabinets open over night to get heat to pipes. As to jrmartin67's explain freezing, It's us coming to where you are in January and everyone there is wearing winter coats and we wander around in short sleeve shirts. Or here when you put a cooler outside, when the power goes out, to store food. The real reason I responded was to ask if or how do you use hot water heater and keep it from freezing being that it is exposed to the outside?
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 10-09-2015, 09:43 AM   #15
As long as you are running the hot water heater either electric or propane, it maintains 8/10 gallons of hot water. No freeze issues there.
Old 10-09-2015, 10:00 AM   #16
Send a message via Skype™ to Falcon35
The one thing that you need to make sure is protected is the valve on the back of the fridge for the water dispenser/ice maker. The arctic pak has a heater the valve but it must be turned on as that area is not well protected. Do not ask me how I know but have shut the water of to the fridge. We had the valve replaced but they didn't put the arctic pak back properly so I have just shut the water of.
2012 Georgetown 378TS Fire Mist
2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Protect-A-Tow
Falcon35 is offline   Reply With Quote
Old 10-10-2015, 08:49 AM   #17
I made a number of modifications to my 2011 Georgetown 327DS to support cold weather use. The Arctic Pac on my unit, as far as I can tell, does not heat the fresh water tank. There's also no heat in the plumbing compartment other than what bleeds out through the insulation around the hot water tank. The heating ducts that run through the compartment are insulated and provide almost no heat.
I added a 300W gutter heating strip to the compartment, attaching it with zip ties to all of the pipes and putting a few wraps around the filter housing. The electrical outlet I added to the ceiling of the compartment is fed from the Xantrex 1kw inverter I had installed behind the sink when I bought the unit. A remote reading thermometer was added to the compartment to allow monitoring the compartment temperature. The heating strip has its own thermostat and draws no power once it's not needed any more.
I use electric space heaters inside the RV and run from internal water all the time. This limits me to staying in RV parks at night or running the generator. The fresh water tank is filled in the morning once the temperature rises above freezing. Bubble foam covers for the windows make a significant difference in internal temperature because we don't have double pane windows.
I saw the effects of not shutting off the hydrant at an RV park a couple of years ago. The hydrant pipe froze then broke and turned into a sprinkler. The park owner told the RV owner that he's have to pay for the repairs, around $1000 for parts and labor - remember, the ground was frozen and would take a lot of work for a plumber to dig up.
Phil
pmsherman is offline   Reply With Quote
Old 10-10-2015, 09:50 AM   #18
rampddc's Avatar
Good Video that may help you. https://youtu.be/n5RGlcLSrM4
Ladysmith, B.C.
Brent and Gail
Royal Canadian Air Force - Retired - Sgt
2008 Georgetown 374ts
rampddc is offline   Reply With Quote
Old 10-10-2015, 09:18 PM   #19
We were at 25 deg when we first got our unit, no issues. It was one night. We were told that these units are really 3 season campers, there is no real protection under the unit. The tank heaters will help some.
I do not like to use propane, so we keep a small oil radiant heater for sold times and set the furnace on 50 or so. So far, the furnace has not come on.
Some people put a small light in the water pump and the water compartment to keep things warm.
With our previous camper, we had a wrapped underbelly and the furnace blew air in there to keep stuff warm. We have been down to 20, had the hose freeze, but we have never had a problem with the sewer hose. i guess that if you had a loop of standing water and really cold temps the sewer could freeze.
I made a home made heated hose with a 25 ft hose, heater tape, 1 in pipe insulation and a ton of duct tape. It has worked like a charm down to 20.
We are going out for turkey day, so we will see how we fair.
happywhencamping is offline   Reply With Quote
Old 10-19-2015, 07:06 PM   #20
Our GT has the heater strips which do real good job in keeping it warm without having to use the furnace and propane. Check and see if your GT came with the Heater strips
DRNoes is offline   Reply With Quote
camping, georgetown
