Old 04-29-2016, 06:45 AM   #1
Georgetown Door separating
I am wondering if anyone else has had this issue. I have a 2014 Georgetown 335DS and have had very minor issues with it. My wife and I are full timers and when I was preparing for next adventure I notice the bottom of the door was separating by the hinge when the door is closed but comes together when the door is open.
Currently I am not close to a dealer and was wondering if anyone new of a fix I could do. I do have the extended warranty but don't want to lose it to a dealer for months
Attachment 106432Attachment 106433
Bevkevrv
Kevin and Betsy
Florida
2014 FR Georgetown 335DS
Bevkev is offline   Reply With Quote
Old 04-29-2016, 09:25 AM   #2
Iggy's Avatar
Your picture is invalid and you may have to try again.
With what you described you have a few options being out of warranty.
Being a 2014 I haven't heard of any doors separating like you described.
1. Get the door replaced which would be costly by your dealer.
2. Find a local RV salvage and see if they have something that will work.
You still will have to have it installed and painted.
3. DIY fix would be to drill a hole thru the door at the location of delamination and install some type of bolt/washer setup to pull it back together and just live with it. This would be the least expensive method.
4. Take it to the FROG Rally in Goshen and write it up as a issue on the form and see if Forest River will replace.
Good luck
Old 04-29-2016, 09:31 AM   #3
Thanks for the reply. Sorry about the pictures I uploaded them from the site. I will see what went wrong. My extended warranty should cover the door. I will just have to locate a dealer that will do it in a timely matter.
Bevkevrv
Kevin and Betsy
Florida
Old 04-29-2016, 06:40 PM   #4
You can also drill a small hole in the center of the delamination and inject epoxy, clamp, and let dry
It's what boat owners do.
2016 Georgetown 364 TSF
2015 FunFinder 242BDS traded for above
2014 Starcraft 1221 Comet traded for above
Modmike is offline   Reply With Quote
Old 04-29-2016, 06:44 PM   #5
Modmike,
Thanks for that idea. I hadn't thought of injecting epoxy. That might be an easier fix
Bevkevrv
Kevin and Betsy
Florida
Old 04-29-2016, 06:49 PM   #6
You can even get an acrylic bathtub repair kit to fill the hole. I used one once and you have to look hard to see where the patch was.
Old 04-29-2016, 07:40 PM   #7
Wish I could get the pictures to upload as it really isn't a hole. I'll try again with the pictures.
Name:	ImageUploadedByForest River Forums1461976767.424701.jpg
Name:	ImageUploadedByForest River Forums1461976796.552258.jpg
Bevkevrv
Kevin and Betsy
Florida
Old 04-30-2016, 09:21 AM   #8
My door did something like that. It was caused by the door opening up to fast and stopping by the way of the gas strut pulling the door apart at the frame. Forest River replaced the door. But it was under warranty. I really think it is a design flaw.
Contact Forest River and many they will help out some or all.
Good luck
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 04-30-2016, 10:46 AM   #9
Wrapper man,
Thanks for that info. I will contact them Monday. I also have the extended warranty so I think it should be covered.
Bevkevrv
Kevin and Betsy
Florida
Old 05-01-2016, 12:02 PM   #10
Bevkevrv
What I meant was if you had to drill hole in the door to inject the resin through. In your case it looks way easier to fix than I originally thought.
If you can remove the door simply put it on a sawhorse and inject fibreglass resin (epoxy) between the delaminated sections, clamp, and let dry. Make sure to use proper epoxy resin, not 5 minute epoxy. Generally, the slower it cures, the better it glues.
As to the door shock, mine open slowly, unless the wind takes, then all bets are off!
door, georgetown
