Old 11-03-2014, 01:54 PM   #1
Georgetown Furnace Problem
Recently purchased a Georgetown 32.9 RV. Tried to turn on the furnace to knock the chill off. I read the manual which states as long as you have power and propane the furnace should turn on at the set temp. The fan turned on but not the furnace? Probably something silly I didn't do??
dietzmp6 is offline   Reply With Quote
Old 11-03-2014, 03:12 PM   #2
Recently had a similar problem with my Georgetown. It turned out, after I hired an RV tech that the contacts were not adjusted correctly for spark to ignite the gas. He adjusted it and it has worked perfectly since.
scivilla is offline   Reply With Quote
Old 11-03-2014, 03:39 PM   #3
bend302's Avatar
My refer wouldn't work one time and I found out I had not turned on the gas. I had turned off the gas detector thus the gas was off.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 11-03-2014, 08:23 PM   #4
Thanks I'll take it in to have a tech take a look
Old 11-04-2014, 10:37 AM   #5
kenandterry's Avatar
RV shop labor ain't cheap. Might wanna check a few things first.
1. Make sure propane valve is opened at the tank. (turn valve ON slowly)
2. Make sure the propane gas detector is turned ON to allow gas to flow.
3. Turn on and light all burners on your stove for a few minutes to guarantee gas flow to that point at least. (bonus is you'll get some heat while testing)
4. Does fridge confirm it is/can running on propane gas.
5. Turn furnace ON to a temp well above what it is presently.
How's things now?
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 11-04-2014, 07:30 PM   #6
I tried all but the last step. I placed the temp about 10 degrees warmer. It seemed to blow cool air only let it run for about 30 minutes. I'll try a lot warmer.
Old 11-04-2014, 07:31 PM   #7
Old 11-04-2014, 11:26 PM   #8
ramair's Avatar
sounds like it could be the sail switch has gone out.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 11-05-2014, 06:41 AM   #9
abjb's Avatar
Or the circuit board.
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 11-05-2014, 09:08 PM   #10
camaraderie's Avatar
Idon't know if this applies to yours but mine is controlled by the black Dometic temperature "square" and the first thing you have to do is turn the FAN to AU (automatic) before you set the temperatýre a few degrees higher. Had to call Coach-Net for that little nugget as it was nowhere in any of my manuals! LOL
Good ĺuck!
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
