Old 12-14-2015, 09:10 AM   #11
I think that you nailed my problem Scott. I do have a PROwatt SW buitlt in, by the entry door that has a green light on it and push sensor to turn on and off. It has to be on for all 110 power (including the big ass fridge). But I am thinking that there maybe another part to it by where I found the wiring in the small access panel, that is under the pantry.
I just didn't want to stick my hand in there. But I will turn off all power and dig deeper.
Thanks nothermark too.
I don't know why FR put in such a larger, power hungry ice maker/ refrigerator in a rig that sleeps 4 to begin with!! Its impossible to fill up. I like to eat fresh food and stopping at local farm stands on the back roads of America is all part of RVing.
hugospro is offline   Reply With Quote
Old 12-14-2015, 09:25 AM   #12
Just turn off the batteries and disconnect shore power. If it's like mine you will find the transfer switch plugged into the Prowatt as the cord is only 18" long or so. You need to follow the other two wires from the box and see where they go. I would suspect that they both go into a junction box that has the feed from the power panel and the wire to the outlet that the frig is plugged into. On a new transfer switch these two wires are labelled. If it is the switch, you could wire nut the other wires in the box together (white to white, black to black and ground to ground and your big ass frig should then just work off of shore power while you get a new switch (about $30).
I know...it is the biggest frig we have anywhere....
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 12-14-2015, 06:34 PM   #13
360true's Avatar
Have you checked the breaker on the inverter? You can access it through the porthole above the propane tank (on my 378).
360true is online now   Reply With Quote
Old 12-14-2015, 06:48 PM   #14
chrisbailey13's Avatar
The outlet on the inverter also has a gfci on it that may have tripped. But if you don't have power on 110v, there is likely another problem upstream, as others have mentioned, check the inverter transfer switch.
2014 Georgetown XL 352QS
2013-2017 Days Camped-215
chrisbailey13 is offline   Reply With Quote
Old 12-14-2015, 08:43 PM   #15
Yes Chris and Scott it was the inverter! Good job troubleshooting it for me.
Thanks for everyone's input on this forum. You guys rock. Have a great holiday and I hope Santa is good to everyone. lol
Old 12-15-2015, 03:44 PM   #16
Res. Fridge
Did you check the GFI on the inverter?? It might need to be reset.
Noralle is offline   Reply With Quote
georgetown, refrigerator
