Old 02-23-2016, 05:41 AM   #11
Originally Posted by Bobb36 View Post
you have to be plugged into shore power or to the outlet inside the cabinet with the cord if running the generator. These items do not run off the batteries
Are you saying that FR-3s do not have a transfer switch that automatically switches the 110 volt feed from the shore power cord to the generator?
Hmmmmm...
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 02-23-2016, 06:02 AM   #12
Kenny kustom's Avatar
Hmmmmm...
They do not. There is an outlet you have to plug the shore cord into.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 02-23-2016, 07:18 AM   #13
2016 Sabre 36QBOK
Thanks. Well, on the brighter side, at least if you have a power failure it makes it easy to plug your stick home into the genny!
2015 335DS
Old 02-23-2016, 07:24 AM   #14
bubbles's Avatar
[QUOTE=Kenny kustom;1109547]They do not. There is an outlet you have to plug the shore cord into.
This is the way my 2000 motorhome was but thought this antiquated requirement ended with the arrival of the 21st century. Go figure.
Old 02-23-2016, 09:41 AM   #15
Got it fixed. The dealer had to change out the receptacle in the rear compartment where the shore line plugs into. Apparently it came from the factory bad. Happy camper now.
Truckdogg4 is offline   Reply With Quote
Old 02-23-2016, 03:02 PM   #16
Bobb36's Avatar
There is a socket for the plug for the motorhome to plug into in the basement compartment.
2014 FR3 30DS
2014 JEEP WRANGLER WILLYS
Bobb36 is offline   Reply With Quote
georgetown
