Old 03-28-2015, 04:06 PM   #1
Georgetown Head lights
Question............has anyone made any changes to their head lights...mine don,t seem to reach out as far as I would like on low beam. Is there a replacement or an adjustment. any ideas or thoughts ????
Dogpound is offline   Reply With Quote
Old 03-28-2015, 08:27 PM   #2
43D18's Avatar
Kinda wish ours reached out a bit farther too on low beam but I guess I never thought it was a priority to see about an adjustment. I'm assuming you could adjust them, similar to adjusting any automotive lights, but I never tried it.
Mike & Suz
2014 Georgetown 351
Pontiac Vibe toad
Buck & Patsy, the boston-mix guard dogs
43D18 is offline   Reply With Quote
Old 03-28-2015, 10:35 PM   #3
I'm not sure about the adjustment but l am going to check it out. I know there are after market lights around but which one
Old 03-29-2015, 09:01 PM   #4
DarrenK's Avatar
I had to send pics of my headlight assembly to FR for a warranty claim. They clearly showed the two adjustment screws, (one for up/down, and one for left/right), but thinking I would never need them again, I deleted them. Take a look behind there with a flashlight, and the adjusting screws will be pretty easy to spot...
DarrenK is offline   Reply With Quote
Old 03-29-2015, 10:16 PM   #5
ramair's Avatar
I adjusted mine just do it in then dark and if you have a building close by works great. My low beams work the way I want, if you look at the inside of the headlight area you will see the adjustment screws you should be able to turn with your fingers if not then a flat screwdriver will work. Adjust them how you want. I had my DW sit in the drivers seat and check while I was outside adjusting.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
ramair is online now   Reply With Quote
georgetown, light
