Forest River Forums
Sunline User Photos
Old 11-02-2011, 01:45 PM   #11
copsuno's Avatar
So far my heater has worked good, used it last weekend, with no problem. Would appreciate though if you find the root cause and let us know, just in case some of us run into the same problem.
Logic will carry you from point A to point B. Imagination will carry you everywhere. "Albert Einstein". 2011 Georgetown 360, Bride of 42yrs, and 2001 Saturn toad, what more could you ask for.
copsuno is offline   Reply With Quote
Old 11-02-2011, 02:54 PM   #12
georgetown's Avatar
Just something to check. when we purchased our motor home, our bedroom was an oven and the rest of the coach was cold. If you have any ducts that run through a slide, check to make sure they are not collapsed. We have a kitchen slide with 2 ducts. The ducts run behind the stove and exit out the far end by the sofa. We had no air coming out of them. Upon investigating what was going on, one duct was totally torn in two behind the stove, the other was totally squash between the side and back of the slide. Both problems were done during factory assembly. after that was fixed (ran new ducts) everything was cozy.
2010 Georgetown 330
Ontario, Canada
georgetown is offline   Reply With Quote
Old 11-02-2011, 03:07 PM   #13
georgetown's Avatar
2010 Georgetown 330
Ontario, Canada
Old 11-02-2011, 03:47 PM   #14
Here Here for the voltage suggestion. Most relays on the Georgetown seem voltage sensitive. 13.2 volts GO!! 12.8 NO GO!! make sure the coach battery (s) are charged.
oldprof1 is offline   Reply With Quote
Old 11-02-2011, 07:27 PM   #15
Lottery Non-Winner
Ovair's Avatar
JD, I was not dry camping. I was plugged in to 50A. I suppose it might have fluctuated, but I have no other indication of that.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Ovair is offline   Reply With Quote
» Online Users: 283
13 members and 270 guests
1l243, bama gail, Greene, HondoPatrick, Mountainmanbob, Namchief, nrcamp, onthelake, Rebel702, Rsgtivr6, shooted, sprayking, srj
Most users ever online was 996, 05-22-2012 at 11:04 AM.
Close [X]
