If the Lippert levellling control module is powered from the house batteries, disconnecting them will probably cause the control unit to loose its internal setting of where "level" is. I'd strongly recommend leveling the rig before disconnecting the batteries. When you reconnect them, the unit should reprogram "level" to be the current position. There are instructions available to reprogram the "level" position for the control unit.
Phil
