Old 07-06-2015, 03:33 PM   #1
bend302's Avatar
Georgetown in the Mountains
We are considering a trip out west after the Indiana Rally to Rushmore and the National Parks in Utah. I am nervous about pulling the mountains.
Anyone have experience with the older Georgetowns (mine's a 2005) and these trips?
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 07-07-2015, 01:04 AM   #2
ramair's Avatar
I can not speak about the older ones by I have traveled back and forth from Id to Texas and have not had any issues with the grades and such. I never push the engine but I am in no hurry.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 07-07-2015, 01:44 AM   #3
We have done most of Utah and Colorado pulling our Jeep. Go slow up and use the tow haul on the way down with no problems. I do try to carry as little liquid weight as possible excluding a fridge full of beer. We use the passing lanes and pull outs to let the cars and motorcycles go by when possible. Go enjoy and dont worry.
2014 GT 378 XL
jeffv003 is offline   Reply With Quote
Old 07-07-2015, 03:22 PM   #4
Freds342's Avatar
I have a 2005 342 DS XL, and have been over some of the worst mountain passes in the country with it!
Just got back from a trip to Idaho, where I drove the dreaded 395 from Bishop to Bridgeport, with transitions from 200' up to 9,000'. It's not an interstate, so the grades went up to over 7-degrees, and my 342 with the V-10 and Banks package did quite well, fully loaded and towing a 2005 Jeep Liberty Renegade weighing over 4-K.
We often go to Lake Isabella, where there is one 8-degree climb for over a mile. We bog down to around 40-MPH and 4500-RPM, but have never overheated or over temped on the tranny.
Gopher it!!
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
Freds342 is offline   Reply With Quote
Old 07-07-2015, 05:38 PM   #5
waiter21's Avatar
We have a 2001 Mirada F53 w/V10. we pull a small Honda Civic.
No problems. When going uphill, instead of pushing the gas to the floor and getting constant upshift/downshift, I'll manually downshift, slow down, and maintain a slower speed, and usually higher RPMs (4000-4500). Going downhill, slow down, downshift to a lower gear, let the engine do the braking.
Highest is I-70, Eisenhower tunnel, west of Denver, 11,000 ft. Did the climb at 25-35 mph in 2nd gear, following a line of 18 wheelers.
OH YAH, Enjoy the scenery.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 07-08-2015, 10:36 AM   #6
Iggy's Avatar
Bill I wouldn't worry much about the hills.
Being you have a 2006 Georgetown I hope you do some planned maintenance before you leave.
My suggestions would be to check all fluids
If you need an oil and filter change do it.
Change your air filter if you haven't.
Also make sure you check the proper tire pressures on the motorhome and on your toad.
If you have never climbed and big hills or passes this is what I do.
You usually see or know a climb is coming and I usually pick up speed a little so the rpm's are at a reasonable range 2200 - 2500 rpms before you reach the start of the climb.
I don't use my tow haul mode going up hills only down hill.
Don't be scared to hit the gas pedal to drop a gear or two as the transmission and engine have plenty of torque.
Another suggestion is just stay with he truckers as they know what coming up and adjust speed.
The biggest problem with most inexperienced drivers is you lose your RPM going up hill and when you lose it its sometimes hard to make it up.
So keep your speed up before your climb and you will be ok.
This is my thoughts on the matter and I'm sure others will have other opinions but this is what I do.
Have fun is the main ingredient.
Old 07-08-2015, 05:10 PM   #7
2003 Georgetown 325
Took my 2003, 325S out to Utah and back. Going again in two weeks. No problems but it will be slow in places. Cut out the overdrive and drop a gear. The rpms will increase but the V10 will take it.
Have fun; don't worry, be happy!!
reddiver is offline   Reply With Quote
georgetown, mount
