Georgetown Instrument Cluster not working
I have a 2010 Georgetown with the Ford V10 chassis. The instrument cluster has stopped working completely. i have checked the fuse and it is fine and i have pulled the cluster and everything seems to be ok. Has anyone else encountered this issue and if so what was the root cause? There have been some intermittent issues with the cluster while traveling in the past, the gauges would just go dead and then come back on but now it is just not working at all. Gonna check for ground wires or loose wires tomorrow but thought i would check here first.
Thanks in advance.
